Topic: odd ball parts needed... (Read 490 times) previous topic - next topic
I need the sheet metal on the C pillar...the old vynal roof rotted mine...you can see where the fiberglass bondo is...I also need the trim around the rear window near the trunk...
I have a SO intake setup and 8 19lb injectors if you want to trade
Is that car light sage green metallic? If so it looks just like my first Thunderbird (an '85 V6 model)
nope tan metallic
if i had a tbird and was ready to remove all trim id GIVE you mine :-| but i have a cougar and not sure if ima remove my trim :-|
bump
