Topic: trans tag info needed 84 4 speed(mustang) (Read 4208 times) previous topic - next topic
Do you have the bellhousing for this transmission? It isn't the same as the T5. If you do have it, KEEP IT!! This is the bellhousing you need to run a Tremec trans!!
James
the srod 4 speed bellhousing? yeah ive got it >:) i plan on pickin up several more of these transmissions in the next couple of years
 with bellhousings tooo.
That's some rather interesting gear ratios for an SROD.....
As you stated yourself.  4th SHOULD be OD.  Can you snap off some pics of this anomoly?
tell ya what.... ill get pictures then when i get them developed..... ill scan em... who knows when that will be probably by early next month
Just dug this thread up while looking up something.  Seems you have a T-04 transmission.
ok.. thank you... still want pictures of this? i can take them and get them developed here this month i beleive. i just primered it... getting ready to paint it white.  btw u dont happen to know if any of the speedo units will interchange into this transmission from a ranger M5OD R-1 or cougar C5 or A4LD?
The C5 speedo unit and gear should work.  All you can do is give it a try and see if it fits and the hold-down bracket lines up.
ok thank you chuck... i cant remember how many teeth the speedo gear has for 3.73's... i think its the orange one ive got...ah hell ill find out... thanks again
