Topic: Another ed A/C Thread.... (Read 2513 times) previous topic - next topic
1987 Ford Thunderbird Turbo Coupe
For Sale
$2300. or V8 Trade.
Thanks!
-DMC24guy
[/SIZE]
Quote from: CougarSE
20inches of vacuum would be enough right Jeremy?
*----Cricketts Chirping----*
Oh yeah. :o
20 inches isn't enough to boil any moisture off, but it is better than nothing at all. If you have a fairly dry system, and renting/buying a true vacuum pump is beyond your means, a venturi pump can pull enough of a vacuum to get rid of noncondensibles. Harbor Freight carries one for ~$15. Name brand versions go for ~$50. They do pull a bunch of CFM though.
The following chart shows the boiling point for water versus vacuum.
Quote from: DMC24guy
For Sale
$2300. or V8 Trade.
Thanks!
I swear, I've seen the heat make people do crazy things here.  It totally screws with people's heads.  I drove mine to work today with the windows down because I'm just plain crazy...and too cheap to shell out $80 to get it re-charged when I've just leardned to accept the fact that you can't escape the heat here in AZ.
