Topic: Horn wire (Read 1117 times) previous topic - next topic
Horn wire
Now that there's a longer weekend, I'd like to add the horn into my alarm system but not sure which wire it is. From the wiring list I had before, there was no such wire color in the steering column. So for anyone that knows, which is it?
1988 Thunderbird Sport
Horn wire
My explanation would be to run slice (with soder and wire gard) "soder wires or no wires" is the motto. run it from your alarm to the horns this is what i had to do. just run it from the main horn wire off your harness not some bs wire lol very simple had to do the same thing daymn prowlers tryed getting my rim's one night and got caught ! thanks to the little thing called backup hooked to your horn ! needless to say the baseball bat came in good use that night !
Horn wire
my evtm calls out the Dark Blue wire off the alarm relay that feeds the low and high pitch horns.
Horn wire
yes its dark blue!
Horn wire
I'm a little confused. I have a purple, light blue, and black wire coming from the steering wheel. Not sure which one is cruise and which is the horn
Chart I have says Yellow/Light Green (-) in the sterring column.
