Topic: 91-92 LSC parts... (Read 1143 times) previous topic - next topic
91-92 LSC parts...
Ive been searching for a while, and there are no 91-92 LSC's in any of the local yards.
What i need from one is the rear dust shields, the rear ABS sensors, and the hardest part, the main brackets for the caliper brackets. These are the ones bolted to the axle tubes, and also have the welded on anti-moan brackets.
If youre able to pull them, ill pay shipping, compensate you for the out of pocket expense, and pay for your labor. Help me out guys.
91-92 LSC parts...
this won't help ya out any...but the JY i was workin at awhile back...had a 91...got crushed about a week before i got there, the boss said it was a perfect interior car...had the HO too, and it ALL got crushed..i wouldn't have minded the engine..
91-92 LSC parts...
How soon do you need these parts? And can you get pics of exactly what you need?
Condsider trade?
91-92 LSC parts...
Im not in much of a rush. I cant get pics since i dont have the parts :p
It absolutely has to be a 91-92, and when you start taking it apart, youll see what i need. You take the calipers and brackets off, and the rotors off. Youll see the dust shield, and this big, thick bracket/plate mounted to the rear, and the dust shield mounts to that, its also the mount for the caliper brackets. You have to also yank the axles out to get those mounts.
If i have anything useful, id be willing to trade.
91-92 LSC parts...
Got any of those trip minders left? I have a complete 91 Mark sitting in the drive way right now that was totaled the engine and trans are going into the cougar.
I also need a larger mass air sensor. All I need is the casting. And a BBK egr spacer. Ya I know not something that everyone has laying around.
91-92 LSC parts...
Im not sure if i have a tripminder handy, but i can get you one if needs be. I can also get you a factory 70mm MAF if youd like. The BBK spacer, out of luck there.
91-92 LSC parts...
Shawn,
There are a few Continentals and older Marks in my local yard. Is there anything compatible with what you need? I would say they are late-'80s or so.
91-92 LSC parts...
only the 91-92 LSC's
I had to pick oddball year items.
91-92 LSC parts...
These what you wanted?
91-92 LSC parts...
You got it!
