Topic: 1st Trip to track with Turbo/install pic on 2nd page (Read 8560 times) previous topic - next topic
Nice setup 5.8fastcat !! Lots of luck with the new mods... Keep us posted the next time she goes to the track!
The offset of the price for twins would not be feasable for the power gains.
You would have to have a place for twins, If you don't want P/S, A/C or any other goodies it would leave you more room. But my car is a street car for cruising and I want a nice ride and A/C  and P/S.
  So 475 RWHP is enough for me.
Yeah 475 rwhp is  good:D . I was just wondering if a twin turbo set up was worth it. How much did the motor make na without the 150 shot?
How streetable is that combo you have now?  I assume since you have a/c and p/s that it is still mild mannered.  Also how is your AOD holding up to that amount of power?
Foxless :(
man that's such a nice, clean car. nice time also. make sure to post a "fixed" run :)
86 thunderbird elan
86 mustang coupe
The trans has held up very well after the latest rebuild. We intstalled 4R70W planteries,O/D drum,OD band, conveted the frt input shaft over to the C6 shaft. Has a Lentech valve body and a Art Carr convt.
 Car is pretty streetable, Haven't put many miles on her yet with this setup yet. The day we ran @ the track a buddies car broke so we put his car on my trailer and I drove it back on the 60 mile trip with no problem.
 Motor was setup for a turbo with low compression it only made 300 RWHP 374 tor on motor only.
 I plan on driving her to CATJAM
I didn't realize you switched back to the AOD. What's up with that? You don't like to shift or something? Don't you owe a viper 6 speed to that motor? :)
"1FSTCAT" - 87 Mercury Cougar XR7, 5 Speed, Powerdyne Supercharger.
"NTRCPTR" - 91 Crown Vic Police Interceptor - 460 POWERED. 14.15 @ 97 MPH, untuned.
With the AOD the BOOST can stay on not bleed off between shifts.
I thought that's what a quality BOV was for?
Not really. A blow off valve's purpose is to keep the boost from slamming into a closed throttle plate, creating a "shockwave" that would normally bounce back to the turbo or supercharger impeller (creating turbulence, heat, and potential damage to the bearings and impeller). Instead, the blow off valve opens, preventing that "shockwave".
What Greg is saying is that a hydraulic transmission (like an AOD) is a softer coupler between the engine and rear-end. The RPM changes during the shift won't be as sudden as a mechanical connection (like a T5), and should result in smoother operation of the boost device.
I built my car as more of an all-purpose car, to have fun with, as Greg's response here sounds like 1/4 mile times and consistancy were his main goal. :)
The main purpose of my car Ed is to whipp  Stangs and Camero  A_ _.
  No I didn't build it just to drag race, I just take it to the track to have a good time. I handles well, the A/C is cold and the power window and such all still work.
 If I wanted a Drag only car it would be alot lighter and no acssories.
Quote from: 5.8fastcat
Same here.... Full operating accesories with added passenger power seat... A clapped out and HOT car ain't any fun in the summertime.
 you and your cold A/C!
 --Ed
Gotta have standards  if not you could just own a mustang.  LOL
