Topic: soft pedal after rear disc conversion. (Read 3340 times) previous topic - next topic
well, I need all your help again.  I installed an 87 tc rearend with disk brakes in my 88 sport over the last two days.  my father and I bled the rear brakes only untill there was no air, and the pedal was firmer.  when I started it up, the brakes were SOFT.  the pedal went a good 75% before they started to engage.  drove it a bit, then bled them again.  they firmed up and then went soft again after starting it.  what could cause this?
  thanks for the help.
The MC is probably a bit small for your set-up now too.
well, to tell you the truth, I couldnt find the stock prop valve, I dont think mine had/ has one.  I put a jegs adjustable prop valve in line to the rear brakes right under the metering(?) block. ( that thing right under the m/c)
thanks
That IS the stock proportioning valve.....
so, what do I do with it?  it feeds the front as well as the rear, and isnt that where the piston is?
You did almost everything correctly. :)
The stock metering (prop) valve has to be gutted. Right now it wants to meter the fluid just as it does with a stock disc/drum setup. You need more fluid flow to the rear. The adjustable prop valve will do that, but first you have to gut the stock one.
You need to get a special fixed plug from Ford Racing, p/n M-2450-A. Then, remove the plug from the front (faces front of the car), gut the plunger and spring, put in the new plug, bleed the brakes, and that should help things significantly.
-tastic.  that explains alot. thanks guys.  I dont know if it means anything but the brake pedal firms up if i pump'em.
if im making very little sense, its because im doing all this while running a temp, ugh
You may still have a low pedal when all said and done though.  It is possible though that you probably just could not get enough flow to the rear to bleed them properly
Ok so basically you are turning the stock prop valve into a "distribution" block?
I run a tc rear all stock no mods (for about 10 years now) and the pedel is fine. You really have to bleed the  out of it. I also bleed all 4 wheels not just the back
I still have to wonder how some of you guys can convert to rear disc and still have a "good" pedal on the factory master cylinder...the stock MC bore size is marginal at best for four wheel disc.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
I remember reading somewhere that the 86 and 87 Turbo Coupes had a smaller master cylinder than the 88.  I just finished putting in a four wheel disc into my 88 LX and used a 88 proportioning valve.  I posted a  question as to the part number to see if it was indeed from a Turbo Coupe.
Weren't all 87-88 T-coupes ABS brakes?
yessir, 4 wheel ABS....but the ABS will be non-functional on a TC rear swap...
It'd be way too much of a hassle to get it to work...and it's somewhat problematic anyway, IIRC-i might be talkin' :bs: about that though.
I've got a TC rear I'd like to put in mine, but some ass-pirate  :flame:  cut the e-brake cables some time long before i got my parts TC...
