Topic: Truck troubles... (Read 1019 times) previous topic - next topic
Truck troubles...
never fails, as soon as my truck is running good for a spell it s the bed...maybe you guys can help. It Won't start, starter may drag, then all I get is a click. I noticed this 2 weeks ago. I replaced the solnoid (spelled wrong) with a NAPA special *I broke it today...cheesey plastic compared to what my work sells*...it still clicked...I got underneath and smacked the starter with an object...it fired and drove fine for a few days...then did the same...repeated this all week...then sunday is didn't help to smack it. I changed the starter. it worked good till this morning...now all I get is click again. I tried another battery...CLICK!!! :mad:
Truck:'92 F150 4.9 I6, T-18 4speed...looks like a mazda style starter
it has one small wire and a large wire *both red* running to the top of the starter. and a black one connected to one of the bolts that are holding the starter in...seems odd...could that be the problem?
Truck troubles...
i replaced the battery cables on my 77 F250 and it stoped doing that to me.
Truck troubles...
Could a bad motor or frame ground be the problem? Clean up the ground points first since it doesn't cost anything.
Truck troubles...
Quote from: thundergrowl
that was exactly what it was...they grounded the starter to the aluminum case of the starter...I moved it...works like a champ
