Topic: The best, most Faithful Car known to man....<-PLEASE HELP ME INSIDE! (Read 1702 times) previous topic - next topic
You got the bolt out and no part of it broke off right? If the bolt came out ok then the only reason I can think of as to why it isn't comming out is that one of the spider gears got hot before they gave and perhaps one of them "welded" itself to the pin. Do you have a Traction Lock? I've never taken a Traction Lock apart (I had mine installed by a trans and diff shop) but doesn't the "S" spring or something have to come out first? I could be wrong :dunno:
The bolt did come out in two pieces. But the pin moves past the bolt hole, but no further. The pin will twist and move back and forth but it will not come out all the way. I've had this type of rear apart many times before, i'm sure blue84302 can attest to that....
The s clip has to come out after the pin.. it is wraped around the pin.
I'm gona torch the pin out. I'm good with a torch and I think I can do it without hurting anything.... I would hate to switch this rear with anything else that isn't a tc rear. 10" drums, 3:27 trac loc and quad shock brackets....but yes a 7.5.
Oh and the spider gears are what stripped out. The ring and pinion are still meshing like they are new with no slop.
The spider gears likely wore grooves in the pin. I had the same thing happen to my old '88 Cougar. I, too, had to cut the ed thing out...
Well tomorrow morning i'm gona cut it... uhg
