Topic: Help 66 Mustang with a EFI 5.0 HO (Read 1124 times) previous topic - next topic
Ok I'm having trouble finding info on this so I figured I'd ask here. A friend is trying to put a 5.0 HO into a 66 Mustang. He has a complete 90 Mustang doner car. He's going to convert to power disc brakes so here's a couple of questions.
1. Can the 90's brake boster be used in the 66 or do we need another one?
2. Does anyone make a tank for 64-66 Mustangs that can be used with the EFI pump as well as pre-bent fuel lines?
most people use pre 1981 ford granada front brake/ suspension parts    to upgrade the older fords
Another (probably dumb) question. We have to change the oil pan to a 60's small block front sump pan. I know we need a new pan and oil pump pickup but will the stock 5.0 HO oil pump work or does that need to be changed as well?
Quote from: thunderjet302
yes you will need a front sump pan, and the correct pick up , im pretty sure the pumps are the same.
i would invest in an arp oil pump shaft to prevent future problems.
You can use a Econoline external fuel pump, and just plumb a return line back to the tank...
Thanks that will make running fuel lines much easier:D
