Topic: Gas problems. (Read 1775 times) previous topic - next topic
Gas problems.
How do you know when your sending unit is bad or the float is off? I'm curious because on  Saturday I filled the T-bird up and it was a tad bit above empty and my low fuel light was on, so I filled it up and it only took 10 gallons.  I researched and found that the 83-86 T-birds have 19 gallon gas tanks.  Why would this be happening? Bad gauge or what?!?!
Gas problems.
This doesn't belong in engine tech, but does the fuel light go off when you fill it up?
Gas problems.
Was told to do a full tune-up.  Cap/rotor, plugs, wires, air filter, fuel filter, pcv valve.
Gas problems.
my 84 does the same thing but mine does takes 15 gallons at empty (no bars left on the diggy guage)
Gas problems.
Sending unit, maybe. My 84 has buttstuffog and doesnt work anymore.
Gas problems.
I vote for the voltage regulator on the back of the guage cluster to be going bad.  Where does the needle read when the tank is full?
Also, your float could be the culprit.  Never seen the style of float on these cars, but i'm assuming that it's not foam - so it could be leaking and on its way out.
Gas problems.
When it's full, it's a little below F, I believe.  Like, right now I'm on like 120 miles with 1/2 tank!!!!!!
Gas problems.
Replace the voltage regulator.
There is a write up here under the tech articles called "guage fluctuation fix".
Gas problems.
another thing to think about is the POS of a tank ford graced is with. Mine is a total POS! if im slightly on an upward slope so the front of the car is slighly higher i cant fill up my car thanks to the huge Flat tank which BTW has  for Baffling to keep fuel at the pump.
RIP 1986 Turbocoupe
1988 Mustang GT Show car/weekend racer
1986 Mustang T-top coupe The 2.3T project
1977 F250 400 4wd Fun in the mud
1997 Honda CBR F3 For when i want to make everything else feel slow
Gas problems.
Yeah I punched the gas going around a curve with 7 gallons of gas in the tank once. Engine died and came back to life as the fuel slushed around :mad:
