Topic: Side motion in rearend (Read 2970 times) previous topic - next topic
There is wear on the end of the axle where the c clip goes.I am wondering about something called a c clip eliminater.Or replacing the axles.Something called a moser axle.I don't know anything about any of this.
i think some side play is normal. every tbird ive had had a little. if you push the car from side to side by the trunk it will go ...plunk, plunk, plunk back and forth...
~John~
Quote from: shame302
Not mine :D
The '84 shop manual says up to .030" endplay is ok.
Quote: "Be sure to measure the end play with a dial indicator; not by feel. A guess usually feels like far more end play than there actually is."
It is adjusted by making a shim the same shape as the C-washer and intalling it behind the C-washer.
Must have a minimum of .005" end play.
Does anyone sell the Clutch pack for the 7.5 rearend.Ford charges 200.00 for it.I can buy it for a 8.8 for 54.00 but that will not work.
