EEC-V cougar to EEC-IV 5.0 HO, can it be done?
Reply #10 –
That diagram is for a manual tranny processor so there are no pins for the tranny. You'd have to get a diagram for an auto tranny (I believe UP-40 is the catch code). Since you'll be starting with a T-bird cougar harness, there will probably be little to no modifications necessary for the gauges and what-not. As far as the tranny there is a bit of modification necessary. The EEC-IV cars use a plug and play harness for the tranny. The EEC V's use a motherboard. You can interchange the two (use a EEC IV to control a EEC V tranny) but you need to know how to re-wire it. There is also an article on that site on how to go about that procedure. To put it plainly, you're asking this question on the wrong site;)
