How the heck to get a broke bolt out
Reply #4 –
If you got a oxy-acetylene torch, use that to heat it up, and try it again with vice grips, usually works....
Or have somebody weld a nut on the end, but you'll want to get that bolt heated up, or it'll just break again.
Sometimes they break off somewhat farther into the hole, that's when it gets really fun, usually involving some serious swearing.
Other than that, I couldn't tell ya, sorry man.
Last time I broke water pump bolts off, was on my f-150 5.0 engine, and I didn't have the torch at the time, so I ended up having the local dealership come get it, and while they had it in the shop, they also changed the timing chain, and put a new pan gasket on for me, since the mechanic boogered up the pan gasket taking the front cover off...
Cost a few bucks, too, about more than the truck was worth.
