Topic: Beefy TC AOD? (Read 3135 times) previous topic - next topic
Beefy TC AOD?
As long as you get the bellhousing from the Mustang (or an 83-86 Turbo Coupe) it will work...
Beefy TC AOD?
you could swap in a c-4:)
BTW i have a 2.3 t-5 direct pull bellhousing. if interested.
Beefy TC AOD?
Quote from: 302Fairmont
speaking of which... I just ran across this today - http://atlanta.craigslist.org/pts/142060352.html
thats a killer deal...assuming it is a c-4 the bell alone will go for 100-200.00
Beefy TC AOD?
Yeah thats what I figured - from what I've heard theyre super rare.  The ad also says C-3 - but would a C3 have been in a 74 pinto?
Should I pick it up and resell it on ebay?  :evilgrin:
Beefy TC AOD?
Quote from: SLEEPER T-BIRD 87
I actually considered that, but now that the opportunity has presented itself....I want a 5-speed!
Thanks, I'm going to the j/y this weekend, they should have what I need but if I can't find what I'm lookin' for, I'll PM you.
Beefy TC AOD?
Ok, just got back from the pull yard...And I am the proud owner of a '86 Borg Warner T-5, clutch, cable, pressure plate, pedals, bellhousing...basically EVERYTHING I need for the swap, assuming everything is ok, for $300.  Even so, the only thing that might be bad is the clutch, which I've located on the net for shy of 100 bucks.  Thanks for the info, everyone.  See you on the road :).
Beefy TC AOD?
awesome man....id play it safe and get the flywheel resurfaced and go with a new clutch/PP. id also go with a new adjustable cable and aluminum quadrant.
~John~
Beefy TC AOD?
Yea, I'll probly go with the cable and quadrant...I'll have to look at the flywheel/clutch/pressure plate.  I'll only be driving it like this until about November, and then March to May, perhaps?  We'll see, I'll keep you guys updated.  Hopefully we'll pull it this weekend. I'll let you know...
Beefy TC AOD?
Are you sure its your tranny can you start the vehicle now? Because I thought that my tranny had also kicken the bucket but it was the flywheel. The flywheel had had seperated, you know how there is a small ring in the center where you bolt it to the crank then the big outer part where the starter engages well it had seperated. I could no longer start the vehicle and when that happen it just reeved.
87 T-Bird turbo'd and supercharged and if things call for it juiced. :evilgrin:
88 Turbocoupe t3, 4.10's, Daily driver
Beefy TC AOD?
Yea, it starts just like normal.  All I have is "Park", everything else revs as if in Neutral.  I'd rather have a 5 speed anyway!
