Topic: tach ??? (Read 1108 times) previous topic - next topic
tach ???
hey guys, just hooked up the accel 300+ ignition,but now my tach don't work.  Tried to look something up in the search but,,,,,,so can anyone tell me what to hook up differently to get it to work?? says something about trying to hook up the tach lead(which one is the tach lead??) to the green wire from the box. I remember someone on here talking about this before.,,,also I just got me a SD/HO puter and some 19# ford racing inj., is there any pro's/cons of going ahead and puting these on??(stock SD, HO upper,throttle body,egr,true duels, crossover with flows) fixin to put on some 1.6 roller rockers, 3/8 BBk spacer and some almn valve covers, figured since i was in there I could maybe go ahead and put these on (yes/no??)
 thanks for any response, Joe
