Topic: Why should I? (Read 2840 times) previous topic - next topic
Why should I?
4.6 4V in a 84 bird?.... Hell yeah!!! go for it! Definetely not for the faint of heart though. Sounds like a tough swap.
We definitely want pics when this project kicks off.
Why should I?
there are different ways too do the swap. some obviously are easier than others. either way, its a much more expensive and involved swap compared too a 5.0 swap. i will try too take pics as i go but im not the best at that...i tend to get buisy and forget about the camera...
~John~
Why should I?
Shame, is your project getting ready to get off the ground?
Why should I?
Quote from: Dogcharmer
I've only scratched hte surface in my research on it, but it doens't seem like it will be all the difficult with the right k-member under the car.  There are enough Fox mustangs out there with it I don't think the procedure in a Fox Bird will vary much.
Ryan[/i][/COLOR]
1986 2R[/b] SVO
1984 T-Bird 5.0 (In Hibernation since 10/96)
Why should I?
its not the most dificlut swap, but its deffinetly no walk in the park. the payoff is huge imho though. once ive got somewhere with it ill start up a thread of my own. (sorry for the hyjack) i havnt realy talked about it much because if i fail then im a . i figured id get it done and running then talk about it. oh well.
i have almost everything i need. im trying too settle on what i want to use for an ignition. their are a few options verying in cost and complexity. i need an ignition and the hydroboost conversion. i need a driveshaft, crossmember/mount and T56 yolk as well as TO and pilot bearing for the T56. um....tie rods, rack bushings, tires, and an exaust and its just about all ready too go. another thing slowing me down is that im powdercoating alot of my parts like my CHEs i got unfinished. in my head right now the color looks awesome but ill probably end up regretting it once they are done. such is life though i guess.........
the engine is palatized and wrapped up on snowmobile trailer at my buddys house right now untill it warms up a little. pics of the T56 are on my cardomain. i need too get the engine up on an engine stand (wich i still need to buy) and shined up some. i need an alt, air and steering pump. motor mounts too.
other than that i have everything i need. still quite abit too go though. i didnt want too drive the car around with the 5.0 on the new suspension so its all pretty much going to get done at the same time.
hopefully ill be driving it this summer, even if i dont get a chance too paint the car id be happy with that.
so far:
4.6 DOHC and T56
5 lug swap all around including new cobra brakes front and rear.
8.8/373
complete new suspension
once i get it running the way i want and work the bugs out, im gonna slamn down the credit card and have basically a teksid block version of an 03-04 cobra engine built up....im a little between that and a built up mach 1 motor. i originally wanted that with the shaker...i love the shaker...
should be sweet ;)
~John~
Why should I?
NO dude get that 03 cobra motor that s/c is soooooo sweet then call classic design concepts and get the shaker too.  The stock cobra motor is a monster and with a little fiddling can put 450hp to the wheels easy.
2004 Impala
Why should I?
welll, i love the 03-04 cobra engines but there is one thing i dont care for about them and thats the cast iron block. id rather buck up and spend the money to have a teksid short block version made up too handle the boost and go with either a ported eaton or go all out on a KB. part of the appeal of the 4.6 DOHC, at least to me is the aluminum blocks. for right now, im using a 98 mark viii LSC engine that i got with only 32k on the clock. its basically a 96-98 cobra engine accept for the fact that it has very slightly/almost the same cams, different intake, and a cast crank. 96-98 cobra engine is rated at about 305HP whily the LSCs are rated at 290HP. i can live with that given the huge differance in cost up front. i had lines on 3 great engines befor i bought this one. one was a 03 cobra drivetrain. it was through a local salvage yard connected too greenleaf. the guy looked it up and it entered their stock the day befor. i put down a diposit, came back 2 days later to fing out that the guy screwed up and should have had me pay it all at once (wich i told him at the time was fine). the other yard that had it sold it too someone else. i was super pissed. it would haave been an awesome deal. then their was a nice 99 cobra engine. i talked too the shop owner and he said that it had 13k on it and he wanted 1800 for it too get it out of his shop. i took the 2 hour drive to go pick it up only too find his story changed and that now its a customers engine that he replaced with a crate engine. the customer wanted 3k for it (wich realy isnt that bad) but he might be able too get him down too 2400. on prinl i pretty much told the guy too piss off and left....pissed off. then their was an 04 mach 1 engine. anouther local salvage yard. the kid called me over the weekend knowing that i was looking and told me all about this mach1 they have. that monday morning, i skipped work to go get it (wasnt gonna let this one go) only too fing out that the manager said the engine was toast and he couldnt sell it or anything off of it...not even a valve cover or intake...long story short, i finally found a 98 LSC that had been tboned with only 32k on the clock. the nose was tapped as well but the engine is fine. i said too hell with it and had them pull it and now its mine. itle do for now and if i cant get it too work i wouldnt have wasted much money on it vs the thousands i would have wasted on a genuine cobra engine or wven a mach1/aviator/merauder engine. once its running im going too have an aluminum long block built up with decent rods, forged pistons and forged cobra crank, 03 cobra heads, 03 cobra or similar cams (not all that likely aftermarket as their isnt realy a need other than too get that lope at idle), billet oil gears, ported eaton, etc.....im not looking for a 9 sec car...just a good strong modular runner. as much as i love the mach1 shaker intake and would love it on my car you cant use one with a PD blower like the eaton, at least im 99% sure you cant. i think i like the eatons wine better than the look of the shaker anyway. i know i could build up a NA 4.6 dohc powerfull enough for me and use the shaker but its so easy too get over 500HP with the 03-04 cobra engines...a tune,intake, pully, and exaust and your just about their.....
~John~
Why should I?
Are going to go with an aftermarket k-member or are you modifiing the stock one?
Ryan[/i][/COLOR]
1986 2R[/b] SVO
Why should I?
i have the AJE k member
~John~
