Topic: new pic of the bird on telstars (Read 3587 times) previous topic - next topic
Quote from: Turbo Coupe
what size rear tire are u running?
275/50r15 BFG drag radials
1979 Ford Fairmont
[/B]
sweet sweet, looks mint, is that on a 15x8 wheel?
it sure is, with 5.5" B.S.
1979 Ford Fairmont
[/B]
added eibach drag springs yesterday.
before:
http://www.mustangmods.com/ims/u/225/588/35490.jpg
2 coils cut from each front spring, and some kind of eibach lowering springs in the rear.
after:
http://www.mustangmods.com/ims/u/225/588/35492.jpg
http://www.mustangmods.com/ims/u/225/588/35493.jpg
for some reason the car doesnt sit level. it could be due to the amount of weight ive pulled from the car or ????? but i had to put in 4 rubber coil spacers that sit inside the coils on the pass. side rear spring. to level it up a little. the front seems to sit higher, but im not too worried about that. the ride though is much different then what i had before. at least it doesnt rub now, when i take a turn.
1979 Ford Fairmont
[/B]
That's what happens when you cut coils.  Many times, it will take the "temper" out of the coil you're cutting on and weaken the spring.  I NEVER cut coils...bad idea all around....  I'd be surprised if it isn't an evil handling beast on the road.  :)
The future...
...because life is just too short to drive boring cars...
Quote from: TBirdNutt
i cut the old stock springs(1st pic). the drag springs are not cut(2nd and 3rd pic).
1979 Ford Fairmont
[/B]
OIC....  nevermind then.  :)
The future...
so how much for the draglites? and what size were they?
