Topic: Body Mods (Read 12447 times) previous topic - next topic
Re: Body Mods
GTS front ground effects, sides and back are McK Plastic ground effects, turbo coupe hood with the scoops plugged, removed the amber lense from thr front corner lamps, removed the reflectors from the rear tail lights, 2000 Audi "brilliant yellow" paint, blue Californeon light up pin stripe surrounding the car...... more to come soon
Re: Body Mods
...custom rust spots?
Re: Body Mods
The list is so long I will have to let you guess
Little taste of the past
Re: Body Mods
Quote from: Cougars 2 go
I changed all the front lights, black-chromed the chrome, will be changing the grille, and already in the process of back-lighting my side valences.
Well, I guess since people are posting pictures, these show one of the mods:
Re: Body Mods
 I still think thats the best looking cougar around,  I just wish I had a wall paper sized pic :)
Re: Body Mods
those headlights are awesome, where's the stcky showing how you did it? :p
Re: Body Mods
same here, Those headlights are gangsta. My body mods are custom paint job, clear turn signals, Big huge ass dent on the side, bent
 frame, and foglights. lol :giggle:
Re: Body Mods
i left a sticky in his garage when i saw progress on it, pics dont do the car justice
Re: Body Mods
I managed to mount Pilot PL-220 (clear) fog lamps in the stock air-dam openings in my '87 T-Bird (non- T/C, of course). It requires taking off the lower half of the nose and mounting the lights directly to the fiberglass bumper underneath the plastic nose. The trick was to come up with a spacer that let the lights hang low enough so that they sit exactly in the center of the air dam openings...this *will* make you laugh, but the perfect spacer turned out to be sections cut from the plastic handle of a kids' hockey stick (okay, it was all that was available, but it works wonderfully). The stick is just a hair (maybe 1/8" to 3/16") thicker than is needed, but since it's hollow, it will compress to the right thickness as you tighten the bolts down (so make sure your neighborhood hardware store is open so you can get the right length bolts). Lock washers are a must, but once the lights are in and wired (I used a stock panel and switch from a T/C) they make a base car look *so* much better.
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Unequal length headers
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
Re: Body Mods
Quote from: Rwolf
Quote from: zpyro
Quote from: kissmaoss8701
same here, Those headlights are gangsta...
Quote from: Tbird232ci
 folks, thank you very much for your kind words.  It's quite humbling to hear folks refer to something I did with such praise.  :cheers:
Re: Body Mods
quit avoiding the question, how did you do it?  :giggle:
Re: Body Mods
I'm guessing he somehow used those round lights and mounted them to the existing headlight bucket, or the hole through which the headlight harness feeds, or at least a part of it.  How they're secured... no idea.
Re: Body Mods
Cougars 2 go  mark my words.. I will Figure out how you did that :evilgrin:
Re: Body Mods
It's nothing major and besides, everyone will (hopefully) see it at Cat Jam.  (I thought I have already told a bunch of people how I did it?)  Anyway, once you see it, you can see how I did it.
