Topic: Led Wtf (Read 1557 times) previous topic - next topic
Led Wtf
i missed u guys. What is the major malfunction with LED can i not just replace my old incandescent bulbs with LEDs.  If not what do i have to do to use these f#@*ing things.
2004 Impala
Led Wtf
What bulbs are you trying to replace, and what type of LED are you trying to replace them with?
Led Wtf
I want to replace the 194s in my dash and all ot the taillamps i plan on getting the sequential turn signal setup from you later and i think the LEDs would look sweet
2004 Impala
Led Wtf
In that case, yes, you can replace the 194's but you may not get even lighting. LED's have a "spot" beam while 194's flood the whole inside of the cluster with light.
With the tail lights, you can install LED 1157 or 3157 bulbs, but you'd probably find they won't be very bright behind your Cougar's stock light housings. YOu will also have to keep regular bulbs up front so that the turn signal flasher flashes, or youll need to add some load resistors to the circuits if you want LED's at all four corners.
