Topic: Headlamps (Read 1493 times) previous topic - next topic
Headlamps
Hi, I just finished rewireing my headlamps.
What a differance!
I put in a one relay for each side directly connected to the battery over a fuse.
Cut the feed wire to the headlamp and routed it to the relay coil and from the relay to the lamp wire.
The relay has a mounting hole which fits over the bolt for the light bracket, easily done.
This gives full voltage to the lamp, no loss over the headlight switch and multifunction switch and the switches are not loaded so they won't burn out as quickly.
First I did the driving beams but when they ended up much more powerfull than the long distance beam I did them also.
(4 relays two fuses).
Its essencially the same conection schematic as you would use for extra fog lights.
BobNorway;)
There are only two tools you will ever need:
1) WD40
2) Duct Tape
If it doesn't move and should, use the WD40.
If it moves and shouldn't, use the duct tape.
