Topic: Road Raced the Cougar! (Read 5890 times) previous topic - next topic
Oh yeah, one more thing. I noticed you mentioned wanting to lower your car. I'll be selling my cut Turbocoupe springs soon. I recently scored some Suspension Techniques springs. Anyway the cut TC springs are installed in this picture so you can see the ride height they provide. They dont rub at all either. E-mail me if your interested. dogcharmer69@hotmail.com
Quote from: Dogcharmer
Man, that sounded like a blast! We have very close set ups. I would be careful about increasing front roll stiffness with a bigger front bar. You could actually make your understeer problem worse. I have the Turbocoupe monster 1 5/16 bar in front and camber plates with 2.5 degrees negative camber dialed in and I still understeer on corner entry. My next step is to increase rear roll stiffness by adding my Suspension Techniques springs (much stiffer than stock TC springs) and some Koni reds and then maybe an adjustable rear bar like the one from Steeda (http://www.steeda.com/). I don't know if that Steeda bar will work on our cars though. It will if the frame rails are the same distance apart as the Mustang but I've never measured. Also I plan on experimenting with some smaller front bars. I wish I had access to a skid pad!
By the way. I'm up in the DFW area. I wonder how many other Texans there are on this board.
Hey nice to meet ya! Yup, we have the same problem.  My XR-7 came with the Turbo Coupe bar and its a understeering monster. The rear bar is the same for our cars and 87-93 5.0 Mustangs.  The control arms are in the same place, so the Steeda part should work nicely.  Me thinks me really want that steeda bar.
When I lower the car I will go with http://www.coilsprings.com to make me a set of stock rate springs with a 1" or more drop.  They made a set for our 1978 Lincoln Mark V (2" drop) and they were absolutely perfect.  No loss in ride (same rate), much better handling.
Give me an email sometime, I can add you to the list if you are ever interested in coming down for an event.  There is also an MSR track near Ft. Worth, right up your alley.
pro-five-oh
Here's a pic!
The Cougar is putting the hurt on a new 6-speed GTO. The GTO would do about 115 in the straights, I would do 90...so he would catch up in the beginning...but after a lap or two my corner-carvin' Cougar would make him disappear.
Though this track is definitely about high horsepower, it has enough curves to keep a smart Fox-body guy ahead of most anything else. ;)
pro-five-oh
I so Envy you.
Quote from: pro-five-oh
Here's a pic!
Trust me it is the driver of that GTO, not the car that made it slow in the turns. Very cool to go road racing in a big car like ours!
James
Quote from: srv1
Of course, but I'm all about blowing away people's notions of what a fast car is. :p Though the GTO is pretty soft in the corners, I was expecting more roll control when I rode shotgun in it.
Doesn't matter what you drive, its HOW you drive.  I couldn't beat a GTO, C6, C5 and the others if a talented driver was drivin' them!
pro-five-oh
Its cool seeing cars like ours go around the track like that.
Nice Mark V by the way, makes me want one even more now.
85 Tbird 5.0
78 F150 351w
13 F150 4x4 3.5 Ecoboost
I can't stand the looks of those cars, pure ugliness but somehow yours is fornicateing awesome!! Start another thread and post some pics!!
James
Quote from: srv1
James
LOL, how can you not love the funk-a-licious lines of a Mark V?  Its right up there with the Viper when it comes to stunning American vehicle design.
I have a small webpage dedicated to the car, take a looksy. ;)
http://blizzard.he.net/~foxbody/mymarkv.html
pro-five-oh
That thing looks pretty sweet with the vinyl roof and  yanked off.  Makes it look slick.  Good job man.  However I think my grandpa's '68 Coupe Deville convertible has you beat in sheer girth.  His has the 472 (i think) in it but its about as fast as a Ford Festiva with two spark plug wires removed.  I've always wanted a luxo barge all done up on 18's or 20's as a cruiser.  My first car was a hand me down '81 Olds 98 four door so I kinda have a soft spot for barges.
Quote from: 50tbrd88
Nope, those 60s Lincolns and Caddies are smaller.  230in length for the Mark V and 223 for the 1968 Caddies.  That Caddy is a compact, can't even shadow an Excursion. ;)
Ya got be beat on displacement, though. ;)
pro-five-oh
Of course, but I'm all about blowing away people's notions of what a fast car is. :p Though the GTO is pretty soft in the corners, I was expecting more roll control when I rode shotgun in it. . .
I agree, my 93 mark (sensor lowered, SC swaybars, poly bushings) can cut corners with less roll than my '04 GTO. The GTO has a high center of gravity, it's not as low, wide and flat as the mark, not to mention the shorter wheelbase.
Duckin' agents like we was trapped in da matrix!
oooo.. I so need to find a track in MI that does test and tune days. or at least go do some cones sometime soon (grumble grumble, need money for a car). that looks like a blast.
I'd love to weigh my grandpas Caddy.  Any idea what your curb weight is?  Whats scary is thats its a coupe but longer than a lot of full-size pickups.  Had a lot of lux for '68 too.  A couple of my buddies have late 70's Lincolns one of which is lime green (in and out) four door with the factory CB, a 460, and low miles. The other is a Mark like yours except a dark blue color and a 400 2bbl (talk about a dog).
4650 for my Mark (well before the aluminum heads and de-smogging) but I'd assume yours is about the same.  Maybe 4500 or so. The 60s cars had more solid metal parts, but they were smaller, had thinner bumpers and no smog equipment. ;)
pro-five-oh
