Topic: Ignition Locked? (Read 2487 times) previous topic - next topic
Ignition Locked?
Ok, so last night I am about to  make a routine trip to wal-mart and I hop in the cat put in the key and turn the............... DON'T turn the ignition because the key won't turn. The steering wheel is locked as well, but that should not be an issue. Has anyone ever had this problem? If so, is there a cheap fix, because I had plans for fridays paycheck -___-.
Carl
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
1988 Turbo Coupe (RIP)
Ignition Locked?
Try moving the steering wheel back & forth while turning the key. Also try moving the shifter. The lock mechanisims in those can sometimes bind the ignition cylinder up
Ignition Locked?
I will try that, thank you sir.
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Ignition Locked?
looks like I am going to have to buy a new ignition switch. Anything to watch out for when I am taking apart the steering colum? Any suggestions on a good one to get for a cougar?
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Ignition Locked?
Ignition switch or ignition cylinder? The switch normally doesn't bind up the whole shebang.
Ignition Locked?
Quote from: JeremyB
No, it usually burns it :evilgrin:
Ignition Locked?
ignition switch is easy if you can get the key to work, you just pop out the old one, there is a little tabyou can push in and it will pop out, in the run position only.if you cant, just buy a new steering wheel shaft thingy.
Ignition Locked?
Ignition Switch
Ignition Cylinder
