Topic: 300 I6 in the truck getting some tweaks (Read 1154 times) previous topic - next topic
I got a set of 19 lb injectors to replace the stock 12 lb. I'll be putting in a 3" catback,computer chip, and maybe a cam. This is in my daily driver, the '92 F150 4x2 single cab, 300 I6, 4spd manual, in metallic blue.
That oughta wake her up :hick:
Unless you're increasing the airflow of the engine why upgrade the injectors? And what computer are you going to use to run those 19-pounders? The stock computer would choke on 'em...
uh exhaust upgrades...high flow aircleaner...people have did it before with no trouble
and if the 19s are too much then the 14's from the t-bird will go in :flame:
go to fordsix.com this has all been dicussed very recently there
i'll bet it has the 19's from the factory, which ones does it have now?
Quote from: 86Tbuzzard
ive never in my life seen somone need to upgrade injectors because of exhaust, and an air filter.
I mean shiznit, i have somewhat an exhaust, a K&N, and boost cranked up to 21psi, and my injectors are stock...i have a bigger fuel pump and adjustable fuel pressure regulator, but stock injectors, i doubt your I6 will need injectors for anything short of boost or if you actually get a head/cam setup
Quote from: Haystack
it has the 12lb phr
