Topic: 87-88 Fuel Lines (Read 7239 times) previous topic - next topic
Re: 87-88 Fuel Lines
I would imagine you could use a knife to salvage the ends by cutting off the hard plastic.
I did just that on my return line when I did my 5.0 swap. I used the '87 Bird  return line on my TC that was too long(routes differently than the TC's and '88 5.0 cars. Ford wanted to get the fuel line off the frame rail and away from the exaust). What I did was split the end then cut it to the length I needed. To reinstall, I set end on the floor an just pushed it back in place. A little grease and a heat gun and it went right on. As I said this was the return line, I'd very careful when modifing/repairing a pressure line.
Yeah, and thats what Im worried about.  I dont like the thought of bursting a rubber line right next to a ler.
ever thought of going to copper? and all the fittings associated with it?
on the presure side that is.
Actually I think Im going to go back to steel.  It'll just be more fun bending and flaring to do :(  Although better than blowing up
I have used 3/8" aluminum lines on our car. I bought rubber fuel injection hose from Napa to reuse the factory connections at the fule filter & fuel pump. I couldn't get 5/16" aluminum line in the hurry that I needed. I had melted the plastic fuel lines off before the fuel filter. That is what happens when you crank up the fuel pressure and the computer takes over to lean it out. Had to put the fire out with a fire extingusher. Haven't had a problem yet in the last 3-4 years since this has been done.
Our web page
02 Explorer XLT 4.0L
04 F150 FX4 Supercrew 5.4L
02 Saturn SL1 1.9L
09 Vstar 950 Tourer
Thanks! you just bent it up I assume?
Sancho,
You are correct. I used a tubing bender to make the bends. I used a flairing tool to flair the ends so the rubber hose pieces couldn't just slide off.
Hope this helps,
Larry
Our web page
02 Saturn SL1 1.9L
09 Vstar 950 Tourer
Here's a trick way to fix your fuel lines, it's for a Mustang but could be adapted. :grinno:
RUS-651104  FUEL LINE KIT
 Today  $84.69
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Hey good idea! Now just to fix the part before the fuel filter
-Did you double flare the line or single flare it?
I only single flared. I didn't have or have access to a double flare tool.
Our web page
02 Saturn SL1 1.9L
09 Vstar 950 Tourer
What would you guys recommend for fuel lines on my car...351w with the efi spyder intake with 1/2" fuel rails.  I need to go from the factory ends to the fuel rails somehow.  I was considering just replacing all the fuel lines in the whole car, but would like to just get it running now.
