Topic: 87-88 Fuel Lines (Read 7020 times) previous topic - next topic
87-88 Fuel Lines
Anyone replaced them before?  I am interested In knowing how one goes about keeping the quick disconnects and rubber sections in the line.  Any one done it?
Re: 87-88 Fuel Lines
now that you mention it,, i was eyeballing the ends once while putting on a new filter.
I got a closer look at the lines up in the engine bay and noticed the ends do come off.  the heavy plastic hose is slipped over the ribbed fittings which sort of reminds you of an air hose fitting where the hose clamps on the ribbed end.
I would imagine you could use a knife to salvage the ends by cutting off the hard plastic.
what lines to use in place of the old ones would be your option but the fittings do come off,,,,,,,,,,,,i thought we talked about this once already :dunno:
id go back to the hard plastic (schedule xxxx or what ever is oem compareable).  Id make sure that the new hard plastic line does not fit until you heat up the hose with a torch slightly then slip it over the old end.
if you use rubber fuel line hose, its even easier, just use clamps but remember the 40 or so psi of fuel when you tighten them but that should not be a problem.  A little silicone might help  as well.
what makes it hard to judge is the fact that the lines have a hard jacket on them as they transition down thru the pass side of the car, makes it kind of hard to see down near the filter area.  Id probably run my new plastic line thru this existing jacket since it it a protection mesure built in.
Yeah... see in my case that protection layer has done its best, and failed.  After looking this morning I think Im gonig to try and pull the connectors like you suggest.  Just gotta find me some new hard line to replace the rusted stuff.
Quote from: Sancho
what the????
mines plastic from front to back ,, no metal at all except for up in the engine bay that only has two short sections.
yours are metal inside the plastic? :screwy:
thats not original,  someone else has done that.
I have hard lines in some section and ruber in some sections, and judging by the state of the car Im guessing its factory.  Yes, it appears there may have been a shield on them at one point but its long gone.
im lost,,
i thought they were plastic from end to end without any metal,,,
anyone else discover this ?
There is usually a short run of metal lines inside the pass. wheel well, up to where they enter the engine compartment. It's behind the slash shield. :ies:
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
I have them back near the axle/tank
Here is some pics of fuel lines from an 88 Tbird 5.0. There is a short run of metal lines in the front, and after the filter, then back to plastic to the tank. :ies:
Hre are the lines that go to the tank. :ies:
:laughing:  :laughing:
you agree???
cause that may be something that just might consume a weekend for me soon.,,, cant stand the thought of broken metal being force fed to my new fuel presure reg and my gutted injectors.,,
why did you do this to me? :brick:  :mad:
sorry, didn't mean it...lol :ies:
I've never had a problem with them, yet...lol
I just had to do a splice, so I was just going to use the stock plastic fuel line & a Ford fuel union, as called out on coolcats, but then I came across the Aeroquip 1000psi fuel hose from Summit.  Seems better than the plastic stuff on the car.  The syntetic rubber hose is much thicker, plus it has two steel braid jackets around it.
The -4AN size slips extremely tightly (you have to cut the first layer of steel braid off to allow it to expand when going over the metal pipe) over the metal fuel lines in the car.  Add a couple hose clamps & this seems like a good exchange for the stock fuel hose....
I did pressurize today & had no leaks... Any thoughts on this stuff?
V6->V8HO 88 LS
5.0L V8 87 XR7
