Topic: Polishing aluminum (Read 1016 times) previous topic - next topic
Polishing aluminum
Ok...so I got this aluminum tubing that I plan to use to make a cold air intake out of.
I was thinking that it would be nice to polish this stuff and not have to worry about paint, but I've never really polished anything before.
For starters, the surface of the tubing is rather rough, I guess from being put through the mandrel bender. What do I use to smooth off the surface, and what do I need to make it shine? I'd prefer to invest as little as possible into this polishing process. We have some cloth "hats" like you would use to polish a car that I could put in an angle grinder or something...could I use these with some polishing compound?
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Polishing aluminum
most guys i talk to use sand paper, go progressivly finer grit till around a thousand, then use some kind of highspeed rotary polishing bit and metal polish. even just useing a wire wheel will get it shiny, but still rough (the wire wheel scratches it)
Polishing aluminum
Hmm...I might do the wire wheel thing then and go for a brushed finish. That'd be a little less maintenence than a polished finish would be.
Garrett H.
Exhaust sound clip
Another clip
Polishing aluminum
depending on the aluminum, your gonna have to clear coat it with something to keep it shiny. polish will work. clear starts to yellow after a while to. im not sure what the makers of actual polished aluminum stuff use sence it never yellows
Polishing aluminum
I used a dremel to polish. First used the rounded sandpaper type bit to knock down the texture. Then I used the small sanding disk to even everything out. I then followed that sanding by hand with different grades of sandpaper leading up to 2000 grit. It turned out pretty good.
Polishing aluminum
i've polished a bunch of stuff on my stang and now working on the TC but what i would do is Sand by hand from 180-220-400-800. it should be pretty  clean and smooth by then. If it still has scratches that look deep hit it again with 220 and move up. once its nice and smooth i use my drill and a bench grinder with a tight woven polishing wheel. For beginning polishing use Tripoli to get it to a good shine. then polish by hand with a good aluminum polish like mothers or meguires.
RIP 1986 Turbocoupe
1988 Mustang GT Show car/weekend racer
1986 Mustang T-top coupe The 2.3T project
1977 F250 400 4wd Fun in the mud
1997 Honda CBR F3 For when i want to make everything else feel slow
