Topic: 1984 ford mustang GT TURBO now runs!! (Read 3390 times) previous topic - next topic
chuck w, about the koeo test, it should do that even after the fuel pump as ran??? i am working on it tomar! whaoooo!
check your grounds you have just pulled the motor and alot of the times grounds get forgotten. or broken when taking them out.
does the car have rust on it.  check the Ecu Ground did you forget that. bc 2 bad ecus is tough to belive.
ITS RUNS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:evilgrin:    it was a wire! and it was only about 1 inch bad section. yes!!!!!!!!!! it runs you guys dont even know:rollin:
i cant help it................... YAY it runs!!!!!!!!!:D
congrats enjoy the ride.
It's amazing the troubles you'll have with 20+ year old wires that have spent their life undfer the hood with a turbo ;)  (That's why the Tbird is getting a new harness with the MegaSquirt)
Glad it's running.
i know its just crazy! me and my step dad worked on that thing for weeks, got pissed and stoped, so then i took it school and worked for a other 40 hours and nothing. started yeasterday ran some test found nothing. step dad comes up and says, its has to be over here.(refering to the wiring on the driverside) he puts his hands on these two fuseable links, that are about 3 inches from eachother, and says man the wire feels realy soft! so we run some restance checks sure enough thats it. so we put a piece of wire in and try to start it, and nothing i was mad!My grand father said to you have everything pluged in, lol ........ my uncle say no, the injector harness is not pluged in. so we do that crank and it started right up. she has a mis but we were runing out of time cause we HAD to go eat,cause of the hole family tradtion thing:yuck: . so we continue today!!
