Topic: 351w 88tc Swap Questions (Read 3634 times) previous topic - next topic
Quote from: warbird
That's too bad about the shifter. Unfortunately the only aftermarket shifter I have is a Cheetah, and I think I'm SOL using it on a 4 spd auto. It has a C-4 shift pattern on it, but that would make for some high rpm cruising with 3.73's out back.
Thanks again for the quick replies from everyone.
Tom
The C4 pattern will work fine with a AOD, they both have six positions...
I found a picture of some TC mounts in an old Ebay auction, and the bottom bracket looks similar. The TC mount is a bit different on the back portion below the bolt hole, but the bolt hole placement again looks similar.
That sounds like good news on the shifter. I paid enough friggin money for it, so hopefully I can use it.
Tom
