Topic: 87 3.8 FI to 5.0 carb (Read 2328 times) previous topic - next topic
V fan belt: CW water pump rotation.
Serpentine fan belt= CCW water pump rotation.
Quote from: softtouch
Unless you are using the dual belt serpentine setup from a Crown Vic etc(alt and A/C comp are reversed)... They use a std rotation pump...
WOAH.... HELLO the lights just came on...
If you're not running A/C and don't ming moving the Alt to the driverside, this would be a cheapie way to go when eleminating A/C...
