Topic: 2.3 running lean (Read 2232 times) previous topic - next topic
2.3 running lean
Quote from: 460 turbo truck
ok, now i know i have to get some things !! ...any idea on where i could get an aluminum billet flywheel ?! ?
I would not use one on your car.
should i also be running the next colder plugs ?! for my motor,...or the 88 TC motor plugs ?! ....?
you need to use the t/c specific plugs. DO NOT USE PLATINUM PLUGS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
hows about a boost controler ?! where can i get on cheap ! ?
do a search for a GILLIS valve. over at http://www.turboford.org
Be aware anything over 10psi is dangerous teritory on a N/A 2.3 engine.
2.3 running lean
we'll  I 'll tell you to get the autolite or NGK plugs the autolite number is 764. As for your boost controller I say make your own. I made mine for about $10.
