Topic: cam shaft advice (Read 2716 times) previous topic - next topic
cam shaft advice
I went with the TFS stage 1 here.  Just gotta finish repinning the wire harness next week (Finally went Mass Air when I put this cam in) and then do some fine tuning.  I'll let you know how it runs.
BTW with the TFS stage 1 and a set of roller rockers you'll probably need a taller valve cover (whether you get 1.6 or 1.7)  I have the Twisted Wedge heads with the Trick Flow valve covers.  The stamped steel covers absolutely won't work with my setup and neither will the aluminum HO covers.
