Topic: Thinking about installing DEFA engine heater for winter... (Read 2697 times) previous topic - next topic
If the SEFI 3.8 is difficult to install heater hose heaters in, you could buy a magnetic oil pan heater.  Up here they are used very often in the colder temps, but are not perminant ie: you must remove them before driving away.  They cost $40 max and are sold under the name "heat magnet."  Basically, you just stick them to the oil pan and plug them in overnight, or on a timer.
Another alternative would be a peel and stick type pan heater which is more perminant.
What is the coldest temperature in your region.  Unless you get below -20*C, you shouldn;t need any heat source for the motor to start.  Just the proper grade oil.
On my car I have three heaters (coolant, oil pan, trans pan) but I doubt your climate is as cold.  Either a coolant or oil pan heater should be sufficient.
Edit: I just noticed you are over seas.  I'll check ebay for those heat magents.
