Topic: I am new (here are some pics) (Read 3319 times) previous topic - next topic
welcome---- nice t-bird you got there
well im not alone on being the young one with a car here...or having a car before i have a licence..........im 15
interior pics man!
the inside aint much just gauges and shifter but  i will get some pics up i have a c4 in it right now do you really think it would be possible to put on aod on my carbed setup woul it require lots of tuning and do you think it could handle the abuse
:flip:I GOT MORE POWER NOW:flip:
:mad:..BUT I NEED EVEN MORE..:mad:
an AOD is practically a bolt-in minus all the little things. it'll handle some abuse if you build it right. :)
Quote from: darkthunder
Mines an AoD taking about 420 to the Fly so yeah It will handle it.  Me personally i would stick witht he C4, but then again im ot looking as saving anything on gas bills and would like a 3 speed.  You are going to have to lengthen you drive shat though i think the AoD is "shorter" than the C4 not positive though just what tranny shops have told me..
they should be the same length. As far as I know the should bolt right in.Also, converting over to EFI sounds like fun. If you do it you know where to turn for help :)
C4 is slightly shorter...I believe you can reuse your AOD driveshaft. You will also need to move your trans crossmember forward.
depends, are you using the driveshaft that originally came with the car, if so, no probs, that is made for an AOD already, if not, should still be okay but check how much of the input shaft is out side of the trans, that should give you an idea of how much room you have to play with.
