Topic: The easy way (Read 1697 times) previous topic - next topic
The easy way
I know there has to be an easy way to make the frount fox t-bird 5lug without having to change the spindle and everything or is it just the hard and long way to do it lol
:flip: FiLa BaBy~!:flip:
The easy way
87?-93 aerostar front rotors work on the 10" brakes the outside diameter needs to be cut down about .150 thou and use the aerostar dustcaps.
The easy way
someone sells direct replacement 10 inch 5-lug rotors. eric knows. i keep forgetting.
if you have an 83-85 1/2 then get the FRPP 5-Lug axle/drum kit(or the ranger/aerostar axles/drums). as long as you don't mind your wheels sitting in about an inch. check out my Darkthunder cardomain page. i used that kit. :)
The easy way
Bolt-in conversion rotors (per coolcats) is http://www.completebrakeservice.com/
Good luck.  I've been waiting for an answer for two weeks.
I just spent some time measuring rotors at AutoZone and space in my caliper.  It APPEARS the Ranger rotors will fit without being trimmed, but I won't know for sure until it's all apart.
The easy way
Quote from: dimarra
ranger will not fit  .. the hat it too tall and you cant get the nut on it. been there done that .
the aerostar as i stated above uses the same bearings as the t-bird/mustang 10" rotors only the dust cap is differant.
the diameter is just a hair larger but on sevral i done i just clearanced the calipers a hair. or you could turn the diameter down as i stated.
hope that helps some.......
