Topic: CUSTOM Indiglo and White Gauges (Available for ALL Configurations) (Read 38156 times) previous topic - next topic
I now have 2 kick ass designs done and I'm working on one right now.  Expect to see pictures (from me, uninstalled) in 1-2 weeks.
would you be interested in making a set that appear stock when off but have the numbers and hashes light up in green when on and the blue/red/yellow colors for high/low on the gauges light up accordingly?
does anyone know if there is a way to make an 85 speedo operate like a 140, is there a way to program it?
Quote from: Turbo Coupe
I've been playing with revrese indiglo and after my experimentations I can tell you that I could do that for you without a problem.
Turbo Coupe, et al.
85 to 140 MPH speedo conversion:
Long, original directions: http://www.foxthundercats.com/140speedoarchive/
Concise, reformatted directions:
http://www.coolcats.net/tech/advanced/140speedo.html
So, hows them gauges coming?:D
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Quote from: cougarman
I'm still waiting on the indiglo sheets.
do you have this color of green indiglo?:
Yes, I do.
Done much with Mark VII gauges? I had planned on buying white-faces at some point for my '89 LSC. Not sure when that'll happen now with my current situation, but I'd still like to go white-face at some point.
Quote from: Bird351
If you can provide me with a scan of the gauges or the gauge faces themselves I should be able to make them for almost any vehicle.
Reply #39
About that, I need to know how the gauges fit in the cluster.  If any one has any images similar to this it would be very helpful.  This is what the gauges look like so far  I haven't punched out the holes yet.  Cougar man also paid extra fro me to cut out the odometer and trip rectangles along with the rest of the gauge.  I can cut all of it or there won't be a place to connect them.  I need to make sure the little gauges will stay in place.  The tach and speedo only need the needle hole and the two other screws to stay put.  The little gauges just have their shape.  If these ones don't work, don't worry.  I have some extra blue indiglo.
http://panther37.xtothezracing.com/gauges/pics/IMG_0585.jpg <-- 2048x1536
Also, I have reverse indiglo available.  Once I get all my materials shipped to me I can show you some samples.
Reply #40
Here's a few pics of how they fit in, if ya need any more let me know.:D
Reply #41
You're going to have to modify your cluster to get it to work.
Reply #42
you have a pm.;)
(here's a pic of an indiglo TC cluster my son has)
Reply #43
This is where you will have to modify your cluster.  On the yellow lines you will have to sand the lip down smooth so the power connection can get through.
Reply #44
Well, I can sure modify that.:D
