Topic: Post your gauge mounting!! (Read 6638 times) previous topic - next topic
this is off topic, but Glen, is that a dead pedal?
Does Mr. Coolcats and the Hawk still have turn signal indicators?
I do for sure...I hacked up an old TC cluster and just reused the turn signals, high beam indicator, brake light, and seat belt light.
Wiring...that was not fun:
Cools, that's what I want to do. :)
I imagine the wiring for that gauge setup did suck...hell the wiring for my 3 gauge panel was worse than I expected. When you have 4 or 5 wires per gauge, you end up with a whole lotta freakin wires to run.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Bet you wernt able to put the clear plastic from the old gauges over the new gauges were ya. I have been working on a way to get the gauges to mount so I can still have that plastic over the top but its been a little difficult. I have just been too busy having fun with BOOST:D  One of these days I will have to finish mine because Autometer gauges look sweet.
ALl the setups posted all looked good.
Mine looked like @ss LOL
Idea was there :)
Nope, won't work...even if it did, there'd be a hole in the plastic somewhere that you just can't cover up. :) I don't know why but it seems like that plastic just attracts the dust anyway, with static electricity. Even in a convertible I've cleaned the gauges way less with them out in the open, than with the stock/buttstuffog gauges behind acrylic.
,looks like I'm going to have to make a new instrument cluster.Thanks a lot you guys.
Quote from: Tbird232ci
Yes it is....came in VERY handy for track days when I had the stock seats.
Quote from: darkthunder
Yep.....like Eric, I hacked up a factory setup for my Auto Meter gauges. I maintained all the factory warning lights, hi-beam indicator and turn signal indicators. The only difference really between Eric and my setup is the amount of gauges. I did a mock up first with 6 gauges like Eric did but I guess because of my height (6' 3") and my preferred seating position, no matter how I positioned them I couldn't see the two upper gauges as they would be blocked by the steering wheel so I went with 4 instead.
Quote from: EricCoolCats
 I've noticed the same thing.....it keeps very clean compared to when the plastic cover was there.
Glen, I'm 6'0" and have a hard time seeing the gauges too, even the stock ones. I kept monkeying around with ideas for the new gauges and was going to do what you did. Then it hit me: countersink the bottom two gauges. That allowed me to keep the stock configuration, and all the new gauges in their same places, and still see them all. Even though I have to slightly stoop a little to see the top gauges behind the wheel, I'm happy that I did what I did. Just had to be a little patient with the Dremel tool. ;) I love your setup though. Very clean and straightforward with nothing to obscure your view. Cool.
I say.. Kudos to the both of ya. Same ideas, Different execution and they both ended up looking great.
well, mine arnt anything like that :D , lol but here they are...
Frank M
1985.5 SVO
there's mine...I'll try to get better pics
For you guys with the pillar pods, what part # did you use, or where did you get them?  I am considering using one for my guages.  I have seen some on e-bay and in summit but I wasn't sure which ones worked best for our cars.  Thanks, jason
