Topic: 88 TC Brake Help!!! (Read 4704 times) previous topic - next topic
88 TC Brake Help!!!
is this what you guys did?
Find the relay with the T/Y, GY, GY/R, GY/Y, PK/LB wires. Remove the relay from its socket, and jumper the T/Y and GY/R terminals together with a heavy gauge jumper wire. Turn the key to run. You should be able to hear the hyd. pump running in the ABS unit. If you hear it run, but don't let it run for more than 10 seconds or so. If you hear it run, turn the key off and put the relay back in its socket. Now, turn the key on, and depress the brake pedal several times and see if the pump runs.
If it doesn't run, probe the PK/LB wire (stick pin thru wire, etc), and, with key on, ground this wire. Pump should run. If it does, the relay is good, if it doesn't run, but ran when the T/Y and GY/R wires were jumpered, then the relay is bad.
i certainly hope i am not still screwed. >.<**
88 TC Brake Help!!!
Yep, that's what I did.
Honestly, converting to vacuum brakes is not that hard...it's just tough to track down everything you need. Plus I seem to be having problems with brake fluid getting out from under the lid on my MC (I got one of the old-style mc's because I'm poor)
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
88 TC Brake Help!!!
mine runs whenI ground the PK/LB wire after I replaced the relay so whats the deal?  I really hope I dont have to trace all of the wiring.  I havent tried jumping the other wires I'll try it when I get a chance
88 TC Brake Help!!!
Mine doesn't run with the PK/LB grounded. So hopefully I lucked out. :)
88turbo: did you check the pressure switch?
Pull the connector off the pressure switch (5 pins). Put the relay back in its socket. Jumper pink/light blue wire to the gray wire in the connector with the key on. If the pump runs, the pressure switch is bad.
[/SIZE][/FONT]
88 TC Brake Help!!!
Here's a part number I found. E7SZ-2C244-A Anti-Lock Pressure Switch. $151.68 Looks like you have to buy it through Ford.
88 TC Brake Help!!!
And you'd pretty much have to pull the MC to get at the pressure switch anyway...
Garrett H.
Exhaust sound clip
Another clip
88 TC Brake Help!!!
the car im parting out has the vacuum brakes on it already too if you choose to go that way
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
88 TC Brake Help!!!
Ted, if neither of them want the stuff I'll take it. I'm planning on using the original ABS as long as I can(and I just installed my spare on the TC thundergrowl bought).
88 TC Brake Help!!!
Just for the record, I replaced the relay with Part Sorenson MR14 and the brakes work now. :) Happy I is.
