Topic: FWD Cougar wheels (Read 3014 times) previous topic - next topic
FWD Cougar wheels
Well, if you really want some of those wheels, you can use some custom spacers for the front wheels (if you want wider tires at the rear, you can use them too), but another word of advice, the cornering is bad for narrower streets, and parking between two cars is a new challenge....
For measures, i cant give a correct number, Maybe some of the guys can get that information...
1985 Mercury Cougar V6
1989 F-200 V8
1996 Explorer V6
2001 F-150
FWD Cougar wheels
well just in general what offsets should i be looking at for 16in and 17in rims?
FWD Cougar wheels
My Fix is Adding 12 Metal O-Rings per wheel ,3 by one of the 4 sides, all of the same lenght (using a vernier) . I have an inch and i can use the front wheels
Are you saying you have 3 flat metal washers on each of the 4 wheel studs as spacers, and they move the wheel 1 inch out from the hub???
[SIZE="7"][COLOR="Red"]AAAAAAAAAAAAA!!!![/COLOR][/SIZE]
:flame: :nono: :flame: :nono: :flame:
