Topic: The First Trip To The Track :( (Read 3817 times) previous topic - next topic
RUN 1
2.18 60 FT , 8.802 @76.27 MPH 1/8 MILE
NOTES: sputtering/loading up of the line 10 deg intial timing
RUN 2
1.97 60FT 8.502@84.55 MPH 1/8 MILE
NOTES :sputtering of idle/loading up off the line 15 deg intial timing
RUN 3 FINAL RUN FOR THE NIGHT
1.98 60 ft  8.800@86.75 mph 1/8 mile
edit
NOTES:switched to 850 vac secondary.light from idle .10 deg intial timing.
ahh the tuning curve begins::: :crazy:
tonight was a reminder that i really need a gear i was going thru the lights in 2nd gear @4,000 rpm. I think a gear would also get the 60 ft down to a respectable time mid 1.60's.and put it into the 7's.
I also need to try out the n2o kit too :D and to get the carb,timing, and suspension dialed in.
Re: The First Trip To The Track :(
you beat me on my first run.
Keep up the good work, you will get there.
TED
Quote from: Cad-T-Bird 500
TED
It just needs some tlc :D
plus i relized that neither carbs the secondaries were opening on. one has a blown diaphram and the 850 has the black spring in it.
got most of what i couldnt get fixed last night finished up tonight. car feels 300% better then it did. We will be taking it back in two weeks hopefully :crazy:
Quote from: 88turbo
what are you quarter mile times?
all we have local is a 1/8 mile track :toilet:
one could only wish for a 1/4 mile
got a 4.30 gear on the way and working on getting a auburn limited slip unit
You sure about that 3rd time??? It only went 8.8@86.75(with a 1.9 60)after going 8.5@84.5(1.97 60)??
Quote from: TurboCoupe50
yep , i doubled checked the mph and times  the 60 ft was wrong i and i will edit it  it was a 1.98
it has some problems ive traced to an alternator that is only putting out 9v. and the afermentioned carb problems gotta love the 2 brl power :crazy:
got everything fixed and ready for friday night ...
got a 4.30 gear now
lets hope for some high 7's all motor :)
good luck
Quote from: Haystack
good luck
thanks , i will need it
