Topic: Its apart again (Read 2776 times) previous topic - next topic
Its apart again
Well pulled topend of the motor apart again.
Checked rockers and bearings then checked roller lifters and still nothing wrong. Pulled heads off and still eveything looks good now signs of anything touching or rubbing.  Looks like i have to pull bottom end out fo the car and keep digging till i find what was knocking in there.
Had help from my son and buddy of mine that stoped by.
Re: Its apart again
I want a Batman costume now. :(
Re: Its apart again
He dont want to wear anything but that or his spiderman jams.
Re: Its apart again
Just hope you did spin a bearing in that thing.
Quote from: oldraven
Here you go!
Re: Its apart again
Well dont think i spun a bearing.
Knocking was a light knock that sounded like middle of motor.
I did pull one plug off at a time wile the motor was running to see if the knock would change.  If its a bad rod or wristpin when u do this the knock quiets down a bit.
I'm thinking maybe the thrust is gone or something to do with pickup.
Ether way knock is not a death knock its loud enuf u can hear it over the motor and a good 10 feet away
Re: Its apart again
maybe a collosped piston?
Re: Its apart again
well tops all looked OK
Walls look mint too.  rember i only have 1300Kms on this motor that what 700miles.
Might even be a bit of  got in the timing chain area and got smushed into the teath.  WIll post my findings when i find out what it is.
Re: Its apart again
Is that a FRAM oil filter I see? It's kind of hard to tell.
I'd stay away from them. Heard of too many problems due to their poor design and filtering capabilities.
Re: Its apart again
never had prob with them.
Re: Its apart again
car is on the trailer and ready to go shop again in the morning.
Re: Its apart again
"Middle of the engine"? Could be a cam bearing, lobe or a mushy lifter
Re: Its apart again
I was thinking cam bearing as well.
Lifters all look good. and there a tad bit better then stock
Re: Its apart again
hey...i want one of those slick blue clutch cables... :tg:
~John~
Re: Its apart again
That clutch cable is a hays
