Topic: turbo header (Read 7526 times) previous topic - next topic
Re: turbo header
Quote from: Tbird232ci
and he calls our cars junkers
notice you can't read anything...read itr agian and you might no that its gone, wrecked i dont have it anymore, and that was from a totaly different post, mines got 150,000 miles on it the 1988 i bought it in 2001...
:birdsmily:
Re: turbo header
Quote from: slamedcat
And you are the one that has a 400,000 mile TC thats all original and was wrecked and want to throw money at it.
And as a matter of fact I would love to see a time slip for that thing. Why just show a pic of shiny exhaust pipes I would love to see more.
it is gone written off the blue one is a 1988, i bought a newer one, sure it would absoultly take you junker on any given day its
:birdsmily:
Re: turbo header
turbo88...you really need to take your meds and then go back and educate yourself some more.
The point that folks are trying to get across, and either they aren't doing very well or you just can't read is the fact that the STOCK turbos on the TCs/SVOs etc are only efficient to a certain boost level, after that you are just heating the air.  For the IHI's it's about 18# and the (Garrett)T3's is about 22#.  There are other turbos which are designed to be more efficient at higher boost levels.  No one ever said that the cars in your Jack Rousch example were running "stock" turbos.....
You have to decide what your goals are for the car and plan the entire package around that, including the turbo choice.  You obviously still haven't spent alot of time researching yet, or you'd know that the SSAutochrome headers are marginal at best.  yeah they're pretty, but they are pr0ne to crack and SSAutochrome's customer service sucks...period. As for the rest of the parts on that site, if those are Garrett turbos, then they should be pretty good, but again a turbo needs to be matched to your application/set-up.
.not to mention most of your cars are junkers and for the 88turbo guy..he was choked when he saw that my car looks much nicer then his, as you can see how hasn't said a word...
  Maybe he hasn't replied because he's to busy laughing *shrug*.  All I saw was a blue 87-88TC with chrome Cobra R's...4-lug none-the-less.  *yawn*  Yeah it was clean, but you can get over yourself.  My car is nicer than yours....as are SEVERAL others on this site.  However, if you want to try and make yourself seem "special" by putting downs other people's cars, go ahead if it makes your pee-pee feel bigger.
Re: turbo header
:giggle:
Quote from: Chuck W
thats ok my car is a daily driver i own a gt500 kr 68 shelby...
:birdsmily:
Re: turbo header
Quote from: turbo88
:giggle:
and we're impressed?
Re: turbo header
Quote from: turbo88
.what do you know Jack Roush in the 80's run 2.3 pinto's with twin turbo's at 35 psi so i guess they must have been "uneeficent" to.....
ok  35 psi split by 2 == 17.5 psi for each turbo wich is right in the efficancy level for a stock t-3 or ihi
Quote from: turbo88
...not to mention most of your cars are junkers .....
might want to rethink that a little some of our cars are not pretty but make up for it in other areas
Quote from: turbo88
glad you are confident of yourself and car some people may feel your is a "junker "as you state it also
like i said i am not here to start anything just kinda help out spell check is your friend :hick:
Re: turbo header
mabey you should be but i aint impressed by ut ride thats for sure
:birdsmily:
Re: turbo header
Quote from: turbo88
Which one I only own 6 cars which one? Plus I never clamed to be fast I just know a little more than you and have done my homework and been around a few turbo cars enough to know what the hell is going on and how to make it run.
So unless you have a time slip showing that theing in the 12 to 13 sec range don't talk any smack becasue there is always someone faster. And they usualy are driving a Viper.
Re: turbo header
Quote from: turbo88
:giggle:
I highly doubt that. throw up a few pictures
Re: turbo header
Reply #39
my 88 is my daily its got rims and a few other mods nothing  special but still i think it looks cool..the only point i was trying to get trew was that i understood that the stock turbo will not do much better then 18-19 psi, by that time there is to much wear and tear on the parts and you can drastically decrese the life of your engine...but we have to keep repeating this over and over and over...really lets give it a rest.. my shelby is a nice carcar i take to the track  it hauls ass and there aint a lot of them around...
:birdsmily:
Re: turbo header
Reply #40
ill be posting pictures asap...for the other people.. who dont think i got one..why would i lie
:birdsmily:
Re: turbo header
Reply #41
So what engine do you have in this KR???
Re: turbo header
Reply #42
auto or manual?
Re: turbo header
Reply #43
Maybe you should go over to turboford.org and do a search on SSautochrome.  Everything you read WILL be bad.  They did a group buy on their turbos and every turbo(all, every single one) failed within a few hundred miles or even before it was installed.
mods: SDS DFI, ported & polished big valve head(1.89/1.59), Solid lifters, Esslinger roller cam #2277,adj. cam pulley, custom upper and ported lower intakes, 60-1 stage III .63 turbo, powerstroke intercooler, 60mm throttle body, 75pph injectors, Walboro 255HP pump, Kirban adj. fuel reg., ATR header, 3" exhaust, MSD 6al, MSD coil, MSD Launch Control, MSD 8.5mm wires, K&N filter,  Spec stage III clutch, Hallman boost controller, Weld Draglites with M/T ET Street 26x11.5/15
Re: turbo header
Reply #44
*grabs a hand full of boots and passes them around to the cool people.*  sh*ts getting deep in here... :D
