Topic: 85 cougar turbo low miles, misfire w\ boost + (Read 2421 times) previous topic - next topic
Re: 85 cougar turbo low miles, misfire w\ boost +
:ttiwwp:    ;)  :D
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Quote from: 88turbo
I think I have the same problem as wi002ri.  mine misfires and sometimes has no throttle response.  could the dist. timing be off a bit?
Maybe, maybe not.
What is it set at?
Whats the Fuel pressure? Had a small hole in the fuel line INSIDE the gas tank and the car would run fine till brought up on boost, just a pin hole in the rubber line that joins the fuel pump to the hanger....
