Topic: 1967 here i come.... (Read 10921 times) previous topic - next topic
Re: 1967 here i come....
keep us updated. Even though we hate all non fox cars,.... And all of the 80-82's.
nice, though that looked like alot of bondo... :P
i actually like those rear meats.. those are HUGE!
I got no choice to use lot of light mastic and bondo...
Since the car will be painted black, it would have been a lot wavy if I didnt did that.....
My pass side is almost finished... I started attacking the driver side today...
Did I told ya all?
MY FINGERS HURTS!!!!
Engine is finally out....  :bowdown:
I'm attacking the front of the car tomorrow with the metal brush and rust converter.......  :grinno:  :grinno:
Re: 1967 here i come.... (Updated)
here's my final black primer layer on the pass side. (The pic may show strange things but I swear, its smooth and perfect...)
and Front part of the frame painted with Tremclad Anti-Rust (Semi-Gloss)
Here's the custom trunk interior I started to do. I plan to use Polyester Resin, MDF rings, Cloths, bondo and Speaker Carpet....
I will apply 2 layer of Polyester resin tomorow over the aluminum foil and will make 3 parts of this big chunk...
2x 12" sub box and a back plate to hide the light in the trunk that I will cover with Gray carpet....
Here's the link where i got the idea.....
http://web.njit.edu/~cas1383/proj/Glassing2/index.htm
man when you say that you are gonna do something you mean it. So far it looks very nice. When its all fixed up your not gonna start hating the fox bodies or turn into a mustang dick are you? Very impressed
Quote from: Haystack
Nah.... no worries...
If I can, maybe i'll try to find a Fox again as daily driver... I really enjoyed every cougar i owned... It was like driving a lounge seated in my @$$ groove...  :rolleyes:
Not a chance I buy myself a mustang...  :nono:
Did you notice, Sly1990, that the can of fiberglass resin you've got there has an '83 Thunderbird on it? Perhaps an omen? :D
Reply #39
Yep... I noticed... I hope it will still stck good even if its not a fox body or a boat......  :crazy: :giggle:  ;)
Here's some updates for those who still looking at this thread...  :D
Removing all that gummy stuff from under my fenders was a PITA and terrible...
Finally its over...
I will put bran new Asphalt Spray (Tar coating) after i neutralised all this rust....
Note : If anyone wonder why one side is black and one is white.
black = Final primer
White = Scratch Filler Primer..
Reply #40
Now the 1st layer of fiberglass and resin was applied...
And as you can see, i spent almost 4 hours to redo my Gas door hole and door.... Now it look F&*%ing good!
Reply #41
hmmmmm you hev the same problem i do........ Old car ... needs work....... very fun to drive...........one difference.... i have a 66 Chevelle
looks good......keep up the good work
Reply #42
nice looking and I want to see how that fibverglass resin works out. I wanna do it to.
Reply #43
 fitting that hood was the worst part i guess...
The hood was still to high by 1½" in the back and I realised the hindge was worn to badly and was kinda torquing in every ways.
After 10hrs spent using lot of equivalent of your "F" word (but in french) at every minutes trying to adjust/shim everything (Fenders, doors and hood) after putting back all the front end togheter, I finnaly decided to remove the springs on my hinges and BOOM! almost Perfect fit....  :screwy:  :bs:
I will finally be able to finish my fenders and hood body work....
Reply #44
When you said "1967 here I come" I though you were talking about the car, but you got that greaser look down good in that one pic.
Nice car by the way.
