Topic: Custom burned chips (Read 2815 times) previous topic - next topic
Re: Custom burned chips
You guys are amazing!  Does the mass-air conversion require a WHOLE harness and computer?  I can just pull it off any HO motor right?
I wouldnt go mass air unless you are looking for major mods. Also it is easy to convert to mass air down the line. You should have to use the harness and you will need the computer. For non mass air you will want 87-88 for mass air go with 89-93. As far as a mark computer, mark 7 that is, they have speed limiters of like 106 mph.
the Mark computer is speed density
all you need is a conversion harness, and a MAF computer for a Mustang, preferable an 89-93, as they have a more aggressive tune than the 94-95's
if you search for something like "mustang MAF conversion" on google, youll probably find a good how to on the subject
Quote from: 1badchicken
As far as wiring here is all you need.
If you are thinking CAM or HEADS I'd definatly go with the Mass Air.  Ebay is also full of A9L - A9P EECs and Air meters you will need.
http://cgi.ebay.com/ebaymotors/Mustang-Ford-Mass-Air-Flow-Conversion-Kit_W0QQcmdZViewItemQQcategoryZ33598QQitemZ7997006980QQrdZ1QQsspagenameZWDVW
