Topic: need help identifing tranny (Read 2021 times) previous topic - next topic
hi
is there a site to help me find out what tranny i just pulled out of my car its been replaced once before from a past owner and i wanna know which on i need to replace it with
thanks kyle
Re: need help identifing tranny
i looked on cool cats and a few others but too no avail
the tranny in your current car? if it has overdrive it's a AOD, if not I believe it's a C4 or C6
yes but thats the prob it has been replaced and i bought it with a bad tranny so all i can go off of is the numbers and letter stamped on the thing or.... is there a tag around there that would say it on the tranny
thanks
kyle
climb under the car, and on the pan, i think an AOD will say "METRIC" and "overdrive" on it, i havnt looked at an AOD for a long time, but i believe itll say that on it
does your car have 3 gears or 4?
yup it has those words but i just wanna make sure its not a C4 i dont know the gears never drove it tranny was bad when i bought it
AOD/C6 - one piece case.
C4/C5 - bolt-on bell housing.
AOD - squarish pan (rear corners taper) TV rod levers.
C4/C5 - square pan, vacuum modulator.
C6 - squarish pan (notched), vacuum modulator.
C4/C5/AOD pan I.D.
C6 pan I.D.
thanks i got the right one today at the yard thanks again
