Topic: steering wheel? (Read 3381 times) previous topic - next topic
steering wheel?
im thinking of replacing my steering wheel, how do I take my original one out?
Re: steering wheel?
Push in the horn button and rotate until it pops out. Then you undo the bolt and unhook the cruise control wires and whatnot and then you pull really hard.
Re: steering wheel?
Sometimes is best to buy a steering wheel puller (if its stuck on good and you don;t wanna break it)
Re: steering wheel?
Quote from: merccougar50
yeah, and ranging from $2-20, its hard to justify not getting one
1988 Thunderbird Sport
Re: steering wheel?
if you got the supplies, make your own steering wheel puller  :p
Re: steering wheel?
all i did was remove the bolt partway, let the wheel lock, rotated it really hard back and forth, and it popped
Re: steering wheel?
I got a really big square punch and had an assistant hit the center bolt with that while I pulled, mine was a bit stubborn, but it came out.
