Topic: harmonic blancer / damper came apart **SOLVED** (Read 19982 times) previous topic - next topic
Re: harmonic blancer / damper came apart
update.......
just completed the use of "heater hose" , the kind with fiber inside and it worked.
vid uploading and forthcoming.  i used the same process to assemble and al went very very well.
i was also able to check to insure there is no crookedness using simple tools.
vid link to part 2 for the win!!
https://youtu.be/3T83w0Bp5Ns
Re: harmonic blancer / damper came apart **SOLVED**
McMaster has sheets of different rubber matts with varying thicknesses.
https://www.mcmaster.com/products/rubber/rubber~/thickness~0-1000/thickness~0-100/thickness~0-1/
1988 Thunderbird TC, 5spd
'21 F150 Powerboost
'17 Husqvarna TX300
I didn't see your last 2 posts of success.  You were looking for material thickness post when I posted that but didn't see that you were already done.
'21 F150 Powerboost
'17 Husqvarna TX300
