Topic: 1980 Thunderbird drag suspension  (Read 5093 times) previous topic - next topic
So I have recently purchased a 1980 Thunderbird that I'm trying to turn into a street strip car. My question is what suspension parts can I use on my car from the mustangs and 83 to 88 tbirds .
Thanks for the help in advance.
Re: 1980 Thunderbird drag suspension
The front suspension is like the Fox Mustangs and the 83-86 TBirds. Control arms/spindles/brakes/struts. All the same. Springs are whatever, but you can use Mustang stuff if you're looking at aftermarket.
Strut mounts are Tbird.
The rear suspension is like the 83-88 Tbirds, in regards to control arm length, as well as shock length and spring rate/load.
They use the "narrow" housing 7.5, which is the same width as the Fox Mustang 8.8. Axles/drum brakes are like the 83-85 cars.
Welcome.
Peruse the site, as there is much info to be found here.
CoolCats.net is a great resource for these cars, as well.
