Topic: 302 oil pan gasket (Read 4291 times) previous topic - next topic
302 oil pan gasket
i ordered a mahle metal/rubberized single piece oil pan gasket but before i installed.  i made a template for future use.
if anyone would like to make their own gasket out of a material such as what i use ( KARROPAK).
i made the templated using "fish paper" which is a telecommunications part aka "fiber paper".
if anyone is ineterested in making their own oil pan gasket, i can mail this template out to you as long as you send it back.
it will fold up into a standard envelope so its not costly.  ask for scott at 304 772 4082 if you want to borrow it.
as for the front and rear part and sealing up things,, just follow my template and these two areas are wide enough to span the grooved out area where you would fill with silicone then use your flat gasket and button up the pan.
i guess what i am saying is i have a template for you to make your own "single piece" gasket out of materia you have.
happy new year by the way
